Hey guys, I am looking to buy a G2 integra…maybe you can help me out a little bit. I found this ad:
1990 ACURA INTEGRA GS-R, 4 cyl., 5 speed, sunroof, music system, 5,900k miles, one owner car, runs and looks good, must see, Frankenstein Motor, Acura set for turbo
now i know there was no GSR in 1990 (right?) so i taked to the guy and he said its an LS bottom block with a 1997 GSR head ported and polished
type R pistons
DC headers
lowered
short shifter
vtec controller
compression ratio 10:1
15" GSR wheels
new tires
This all sounds good but (besides receipts) is there any way i can verify all the parts? like how do i know if its a '97 GSR head, if the wheels are real etc… any tips on what I should look for? and things to watch out for on a performance car besides the usual used car stuff
also how much would all these extra’s add to the price of the car? (i am looking to get a stock car and do all the mods myself, but this one came along so maybe its a good $deal$)
The headers should be simple. It should have the DC logo on one of the manifold pipes. For Compression ratio, get a compression gauge and do a compression test. 10:1 should yield 200psi. BTW, that compression ratio is very low…especially with ITR pistons. Are you sure he said 10:1 not 11:1?
Some questions for you:
What kind of short shifter?
What kind of springs?
What kind of shocks?
As for the pistons, you’ll have to take the block apart in order to tell…sorry.
personally i wouldn’t buy a car that was that modded, especially since its an ls/vtec engine. There is no real way of knowing if that engine was built properly, and how long it will last.
ok…right above the headers, on the cylinder head…there are numbers…if the head is a 97 then the head number would say 96…it will be a little rotated…(not upright)…just look and you will see it…and the intake manifold sould be the dual stage one. if it is not…look to see if it is the skunk2 manifold…and if that is not true, it is not a GSR head.
ok…it all depends on what you want and what u have to spend…
honestly…i wouldn’t by a LS/VTEC engine…only from a company where i have a warranty…
if u want something fast. and you like the sound of the LS/VTEC buy it and rip the head off the motor and see what pistons it has…and while u at it just drop in some CTR pistons…or JE high compression…
if you just rather to have something to drive now and dont have to worry if it would blow up in your face…
leave it alone…and go and look for a stock gsr or ls…and mod it yourself…
