I bought this 91 LS for 500 dollars and im getting all the basic tuneup. So as i was looking into my car i noticed that a lot of the vacuum hoses were going to different inputs than other integra engine bays ive seen on this site
ive numbered where i believe they should go, obviously i havent moved them around, i want to get someone elses opinion first…
can someone tell me where this hose goes?
i hope someone can help me out thnx…
on your second pix, the fitting on the throttle body that has no hose. That one connects to your charcoal can.
the others, you can just look at other engine bays, cant compare it to mine cause mine is tucked.
thanks for the pic
is the charcoal canister located in the pic?
so it looks like im missing the part in green… is that the air boost valve? where does that hose go? i cant really tell from the pic angle…
i think im missing the dashpot diaphragm… item 4… holy hell 50 bucks from stealership… anybody know what item 10 is??? it doesnt say the name of that part on the diagram
[QUOTE=ggodetan;2088013]thanks for the pic
it goes to the intake…
and yes i think so… the picture under the hood calls it the dashpot
DA_all_day do you have a pic of your charcoal canister?
alright so i think i figured everything that was wrong with my vacuum hoses. to fx it i had to, cancel out the egr valve, cancel the hose that used to go from the intake manifold to the control box, which is now removed since my car is manual transmission. i also corrected the line that went from the pressure regulator solenoid valve to the pressure regulator, corrected the line on top of the air boost valve by connecting it to the intake,also corrected the line from the purge control solenoid valve to the charcoal canister ( i didnt realize that my purge control diaphragm was acutally broken). I connected the line from the purge diaphragm to the throttle body. i was also missing the dashpot diaphragm that connects to the intake… it took me a while to figure it out cuz i didnt realize that my car used to be automatic until i figured out what the egr valve was because i was looking on the manual transmission version in my repair manual!!! can somebody tell me if its correct, maybe this will help someone in a similar situation. thanks
i just took a pics of a bunch of stuff for you. the thing with the tape on it nothing. dont even worry about it
thanks alot bro, my charcoal canister IS broken lol… so the vacuum hoses from the dashpot diaphragm and the top vacuum hose on the air boost valve connect together and enter the intake? i cant really tell cuz of that white thing on it…
the little thing that says “up” on it is useless. dont even worry about that. i have that hose just there to cover the plug from it. the hose with the little black thing on it goes to the intake and the big black hose goes to the motor.
alright so i gatta cancel that line and the other line that used to come out of the intake manifold to the vacuum modulator when my car was automatic… i would just buy a manual intake manifold to get rid of all that clutter but im opting for a type r swap :rockon: i just wanna get this one running so i can have a dd
