Well, I searched the existing threads, but still haven’t got a clear pic of what part pries off. Mine has two individual lenses. Do they EACH come off or does the whole cover/trim piece come off? Where do I pry? Wanting to put some bright LEDs in:)
Thanks ,
James
the whole assembly comes off as one. its just held in with clips. you have to pry kind of hard to get it out and i suggest getting one of the plastic or rubber trim removing things so you dont damage your headliner.
but yes, i do believe the lenses themselves come off individually. there should be a little slit on the lens somewhere for you to pry in.
i changed out my headliner about 2 years ago so i dont completely remember all the details.
The whole thing comes off. The individual lenses might also but don’t recall… you pry between the headliner and the “trim” piece. Just took mine off a couple weeks ago.
thanks fellas
you have to try to push the entire Bezel forward and then the front part unhooks and comes down.
wait or is it back. sorry all I remember is you have to slide the entire thing forward or back.
