4-1 header fitment for vtec top end power..
OK so I have a 98 spec jdm type R swap and Im currently running on cracked Ls DC headers wich are skinny compared to the vtec headers… I want to get a 4-1 vtec header set up from ebay but herd that the 4 pipes will hit in the lower cross member and will have to cut it for a snugg fit… Is there anyone running a 4-1 vtec header without having to cut the lower crossmember for clearance… I need some leads to a good 4-2 header so I dont end up buying a traction bar to eliminate the crossmember and fit a 4-1 header…
Buy a 4-1 header that is made for the G2, and it will fit. Buying a standard 4-1 won’t work.
I am running a 4-1 header on my b20 swap and yes I had to cut the crossmember to get it to fit.
I dont think im going to get the same power from a 4-1 header made for our cars VS a 4-1 standard header will I?
First off, if you’re just looking for something to fit and make decent power, it doesn’t really matter which header you go with. 99% of the headers most ppl buy make the same power, regardless of design. It’s about the package you put together and overall goal. Forget about 4-1 vs 4-2-1 unless you’re looking for a specific header to satisfy an overall objective. 4-1s are louder and generally hang lower. 4-2-1s are often two piece making them easier to install. It’s been tested that neither really makes any more power than the other. The age old 4-1 for top end and 4-2-1 for midrange holds true, but the differences are like 1-2 hp. In the grand scheme of things, you can make up that difference in several different ways. So don’t worry too much about it.
If you want a serious header, you need to be willing to get traction bars so it’ll clear. Period. Trust me it’s completely worth it, but only if you’re planning to do some autox or track racing. By serious i’m talking like a real or replica hytech tri-y style header. $500+ or so.
If not, just get yourself a megan, dc, strup, or obx header made for your car and enjoy. you wanna put a couple extra ponies on a dyno to impress, grab a jdm ITR replica header, notch the crossmember and have a shop weld in a support plate to it to keep it from being over stressed (don’t skip this step, it’ll keep the member from cracking). Finally buy yourself a password jdm header skid plate and enjoy.
well my 98 spec type r set up makes the most power at top end, most type r’s do. So with that in mind I rather have top end than low or mid, im kinda used to it. Reason Im looking for a 4-1 is cuz the oem itr header is a 4-1 and all headers for our DA’s are about 1.75 inches in diameter wich is good for the LS flow rate… a newer 4-1 header 94-01 for vtec has about a 2" tube diameter… See my delima… I want the 2" diameter tube header for my type r head to eliminate the restrictive LS headers…
The point is, if you have two aftermarket headers… one that is 4-1 with a 2.5" collector, and one that is 4-2-1 with a 2.5" collector, they both will make about the same whp numbers. There’s no reason to go out of your way to get a 4-1 if you can find a decent 4-2-1 header.
We see your dilemma in a sense that you dont want to use the stock LS header… But what we’re getting at is prettymuch any aftermarket header with a 2.5" collector will be an upgrade, regardless if it is 4-1 like the OEM Type-R setup, or if it is 4-2-1. In fact, tons of people are running the Tri-Y (4-2-1) style header and showing alot better mid-range power, with nearly the same top end power as 4-1 headers.
[QUOTE=unified112;2159099]The point is, if you have two aftermarket headers… one that is 4-1 with a 2.5" collector, and one that is 4-2-1 with a 2.5" collector, they both will make about the same whp numbers. There’s no reason to go out of your way to get a 4-1 if you can find a decent 4-2-1 header.
We see your dilemma in a sense that you dont want to use the stock LS header… But what we’re getting at is prettymuch any aftermarket header with a 2.5" collector will be an upgrade, regardless if it is 4-1 like the OEM Type-R setup, or if it is 4-2-1. In fact, tons of people are running the Tri-Y (4-2-1) style header and showing alot better mid-range power, with nearly the same top end power as 4-1 headers.[/QUOTE]
Ahh I see your point now, here I am trying to figure out something I dont really need… I just lost track of the facts I already have in front of me. I do need help in the mid power range so I guess Ill upgrade from my old 4-2-1 DC LS headers to some newer ones then. reason I was looking for new header is cuz my current ones are cracked and bent… thanks for the shout guys…
Type R’s make power where they do b/c of several factors. the header alone does NOT determine where the power is being made. It’s a package deal. what other mods have you done?
well my set up is a lil different than the oem obd2 type r. I bought the motor complete with everything I need for a straight swap. It included the complete long block, all ignition, p73 intake, 62mm throttle body, injectores, engine harness, p73a obd2 ecu, oil cooler, itr fly wheel, itr crank pully just about everything you would have on a jdm itr swap wish list…
best part is I paid really cheap for everything, just $1k cash… Guy was really hurting for quick cash to make his 2 month late mortgage…
Anyways I wanted to keep everything as simple as possible to avoid regular break downs and daily drive this so I went with the obd0 jdm b16 route. I source a jdm b16 obd0 §§§§§ then had my LS obd0 harness spliced wtih the obd2 sensores on the motor. Found a jdm pwo ecu from the b16 jdm xsi and chipped it with a chrome chip, vtec is set at 5,500k and redline at 9k and Blox FPR.
I have a DA AEM intake, cant really fit anything bigger since nothing else fits in our cars.
DA LS DC carb legal 4-2-1 headers.
gutted cat, and stock muffler to avoid cops. My vtec is laud as hell as it is.
I do have a tanabe hyper medallion axle back muffler that has a 2.5" flow and will install it in with a custome cat-back set up later down.
everything else Ive done is new skunk2 type s coilovers , energy suspension shifter bushings, rebuilt my jdm SIR Y1 LSD tranny.
Well obviously your wish list wasnt complete cuz you didnt get the type r header.
What I did on my last DA was run a 2.25 world sport with test pipe, had flanges welded on either side of both mufflers, that way when I was out messin around all i had to do was swap the stock muffler out for the world sport. So I was quiet when I needed to be, and loud when I wanted to be.
Yup, sounds like all you need is a good header with 2.5" collector and you should have a nicely breathing solid setup.
ok cool Ill get a new header since my current ones are cracked and dented, soon as I get my tranny back from the shop then Ill start on the exhaust…
