7 Flashes on my Computer
My check engine light came on and I looked at my light indicator and it flashed 4 slow repetetive flashes the 3 quick repetetive flashes right afterwards. No, is that my map sensore(4 flashes) or my throttle angle. I have know idea what the throttle angle means and where is my map sensor located. Any help would be greatly appretiated.
Thanks
4 long + 3 short = code 43 = Fuel Supply System.
First try resetting the ECU when the engine is cold. Then if you still get the check light, check your fuel filter, O2 sensor and air vac hoses.
yeah, code 43 is mostly the O2 sensor… get a new one, it’s quite cheap. (about $40-$50)
Thanks for your help
Thanks for you help guys. I will be changing the O2 sensor this weekend.
