hey guys, just did 90-93 swap on my integra. The problem i’m having is that when im in traffic(stopping and going) the tranny goes in hard and come out of the gear hard(1 and 2). and at times it sort of stay engaged and then comes out hard when i slow down. i can feel the car jurking(bucking) forward when the gear is stuck like that. On normal acceleration it shifts soo good not a single problem. i used Honda ATF.
Problems with the car, potential piston rings need changing (burning oil) and im guessing a faulty TPS, because at start up sometimes the idle fluctuates also when driving. ANY help would be GREATELY appreciated. thanks
possibly sounds like the shift solenoids are sticking or the TPS does, i believe, help regulate shift points. so if thats bad it may be causeing issues
yea the same i was thinking…more or less today im goin to get a new TPS, if that does help then im going to get new shift sol. Thank you for your imput!
didnt get time to do anyting guys…been really busy with work…urm no codes from the ECU and no Codes from the s3 light. any ideas? my friend also told me about the lock up torque converter solenoid??? any insights about that? thanks
its possible that you may just need to clean you auto tranny solenoids they can cause all kinds of odd problems i will try to post some helms manual pictures soon.
