Okay, this is strange. I just did a full brake job from the master cylinder to the pads, rotors and brake hoses. After finishing up I check all of my work, double check the parking brake, clean up, and make sure all hoses are connected. I finally get to bed the pads and … the battery is dead.
I try to jump start it but the battery must really be dead because it won’t start at all.
So I swap in a new Optima Red battery. Tons of current.
It will crank and crank and crank, but it won’t turn over. All instrumentation lights are on etc.
This is incredibly frustrating and I’m wondering what the hell happened. It was running like a top before I did the brake job.
I’m suspecting maybe:
Did I knock the throttle linkage out of calibration or something when I moved it out of the way for the Master Cylinder?
Something to do with a booster leak? It was working fine before the brake job and there’s a new rubber gasket in between the booster and master cylinder all properly lubed up.
When I get home from work I’ll get someone to crank it while I manually play with the linkage to see if it’s that. If that’s the problem I guess I’ll have to dig through the manual to find the calibratiojn procedure because I haven’t done it before.
Does this sound familiar to anyone?
eris
