On my cam gears the is that damn plastic guard well i removed my valve cover and come to my suprize i found the plastic gurad that is mouted to the engine block has warped into my damn gears and causing the gears to grind into the plastic!!! how do i remove the plastic shield from the engine block and fix in general???\
Removing it is not fun, you will have to pull the drive pulley off to totally remove it. Well at least you will be able to change the water pump and timing belt at the same time. You will probally have to go get a new or used one somewhere.
Mine has always done that too…I tried wrestling with it when I replaced my cams; but it doesn’t reshape at all. I just live with it. It doesn’t seem to be hurting anything. It’s just unsightly.
Is your’s making any sounds at all? I thought mine was causing a whirring sound; but that turned out to be a worn water pump.
You can cut it off but you leave the timing belt open to damage, you could possibly catch a rock in there which could either tear or make the belt jump, I wouldn’t recommend it.
