Air filter PLUS drag kit
are you running an air filter with your turbo??
if so could you please post pics :slight_smile:
I’ve heard some people don’t use a filter but I don’t wanna run that risk.
btw I do not want to relocate my battery to put the filter on
I have an HKS mushroom filter and 3 inch pipe
How is your turbo situated? ie which side is the compressor housing on?
Since you don’t want to relocate your battery, your not going to have much room. Before I relocated my battery, I used flexible exhaust tubing from Pep boys-like $6 and a motorcycle filter(it’s small enough to fit under the battery mount) I Got a 2.5" to 2" rubber plumbing adapter from Home Depot (2.5" goes on the compressor and 2" goes to the flexible tubing) Cut the tubing for the fit you need.
Eventually, I relocated my battery and got a full size filter, but this setup works just as well. For the record I’m runnin a DRAG kit with the compressor facing the passenger side.
thanks
yep mine is facing the passenger side like interacon’s
ok sounds good.
I have a 3- 2 1/2 inch adapter and 3 inch pipe with a bend in it
as well as an HKS mushroom filter.
looks like its gonna be a pretty tight fit.
might have to pick up a motorcycle filter like you said
any pics guys of a filter mounted with battery intact compressor facing the passenger side?
