Almost dies on cold start ups
Once again,i need the help from my fellow G2 members.
STORY: My car has been feeling like its got no power between 2k/4k RPMs,after Vtec kicks in,i have power up the ass.
Now,when the car has been sitting for a day/night,it will start right up without pushing the gas,but will slow to 100 RPMs and slowly come back up to about 8/9rpms (NORMAL TEMP IDLE)
MOTOR AND YEAR OF CAR: 91 LS with a 94/95 JDM SIR-GSR swap
THINGS I REPLACED AS THIS HAS BEEN GOING ON,BUT IS STILL DOING IT.
TPS,Also timed it right.
Map
Intake temp censor
O2 censor
Coil and igniter
Plugs/wire
Fuel pump about a year ago along with filter
Air filter and PVC valve.
Also cleaned and screwed that plunger thing under the throttle housing
Timing belt replaced 2 years ago,and timing is dead on.
No Cel codes.
I have checked for vacuum leaks with no luck,and also pulled the throttle housing off and replaced the gasket when i replaced the TPS and adjusted that one thingy,lol.
The RPMs isn’t revving up and down,so i don’t thing its the Iacv censor behind the intake manifold,or can it be?
Any help would be great guys,winter is coming and soon it will snow,and I’m scared the car will never start in the cold. Thanks guys.
What kind of ECU? OBD0 or OBD1? Is it chipped?
94/95=OBD1
No,not chipped. The swap was done at a good shop in Cali.
Sounds like a dirty or clogged IACV, so i think thats next on your list.
Good how-to on ozhonda with clear pics, but you may have to register to see the thread.
http://www.ozhonda.com/forum/showthread.php?4693-IACV-clean-check-!
Yup,i was going to do it today,but had to drive somewhere,so ill do it tomorrow for sure.
That rules out ECU issues then. I agree, check out the notorious IACV.
Check the fitv as well.
If it’s not opening when cold, the PCM is reading off the ect sensor and dumping fuel assuming that the fitv is allowing extra air in
Can you please explain what the fitv is? And where its located? I also don’t know what the pcm or ect is nether…lol
PCM- power train control module
Ect-engine coolant temp sensor
Fitv- fast idle thermal valve
The PCM takes readings from the ect sensor and adjusts fuel trim accordingly. When cold, the fitv allows air passed the throttle plate which speeds up idle rpm. At the same time, the PCM is reading the coolant temperature and allowing more fuel into the cylinders to compensate for this extra air that the fitv is allowing past the throttle plate. If the fitv is stuck closed, The engine can flood when cold. Because of the lack of air
Fitv is located on the side of the passenger side of the intake manifold, under and to the rear of the throttle body.
That would be the one with 2 hoses,right? I already cleaned that and adjusted the plunger,and also replaced the censor on top of the throttle housing and also the TPS.
UPDATE:::
ITS FIXED<OMFG ITS FIXED.
IACV was dirty as F##K…lol
