Alternator bolt sezied...help!!!
Rotating the square end a bit will hopefully loosen the bolt so you can slide it out. It should come out. Thought your problem was that you couldn’t even move this bolt after taking off the nut. Does the alt swing up and down on this bolt without turning the bolt? Because that would, of course, mean that the bolt is loose in the alt. If the bolt turns in the brkt when moving the alt, then the alt is stuck on the bolt.:werd:
you’re not talking to me are you…lol…damn.I feel stupid
