So, this would be the 3rd time now in one and a half years i had to take my car back to Les Shwobs “or how ever you spell it”. My front shocks keep going out and they don’t know why. Well, the first set was Eiboc shocks and in less than 2 weeks,they went out after paying good money on this shop to lower the car with all the right stuff “I LIKE TO DO THINGS RIGHT THE FIRST TIME”. So i take the car back and they say i had the wrong shocks for lowering, so they put some gold color looking KYBs on and sent me on my way thinking they got it right this time." Well" today I’m driving home and my car starts to bottom out on the smallest of bumps, so i take it back and “LONG BEHOLD” the shocks are out again and now i have dents in both towers. So to make it up to me, there going to replace all shock with KYB AGX Adjustable Gas Struts to pay for the damaged towers and they are sending me to a body shop to have the towers fixed and repainted “all free”. I need to know if AGX Adjustable Gas Strut are good so i don’t end up having to go threw this crap again. http://www.kybshocksonline.com/Prod_detail.aspx?AAIA=1000225&pid=1174
Thanks guys
Video http://www.youtube.com/my_videos
My setup as of now.
Left side tower
Right side tower
I have agx on my accord and think they are junk.
How low is your car? Camber kit? There is no reason for your a-arms to be hitting unless you are super low or have a camber kit.
[QUOTE=Luciferi;2158483]I have agx on my accord and think they are junk.
How low is your car? Camber kit? There is no reason for your a-arms to be hitting unless you are super low or have a camber kit.[/QUOTE]
I’m set at 2 1/2 with Eiboch camber kits.
just get coilovers and call it a day. get some buddy clubs theyre only like 700 and you can lower your car as much as u want cause theyre designed for that purpose without loosing shock travel. i wouldnt even risk the headach of replacing the shocks and risking them blowing again. do some more research.
I had coilovers and did not like how they ride. I also have free life time replacement so I’m going to stick with that for now. I don’t think researching is relivent to this thread but i did do research. I just want to know what others think of the shocks in question,that’s all:burnout:
here is a thought maybe you springs are bad an do not have the spring rate they should an that why you keep blowing your struts. It just a thought tho as I have seen your car an my car is way lower then you an i dont bottom out like that matter fact I think my 4 door might be lower an it fine with tokkico whites an soil overs
Yeah the spring are all good. I had them tested today because they thought that they might be whats wrong. The driver side shock is leaking a little.
A friend had KYB AGX adjustable shocks on his CRX and I was never really impressed with them.
If I was in your situation what I would do is see if that shop can get Koni Yellows. They are only $116 on Tire rack as opposed to $93 for the AGXs. I would offer to pay the difference between the AGX and the Koni. You will know for a fact that the Koni’s will offer as little damping as stock or as much as you need for 800 lb springs (I pulled that number out of my ass, BTW) and they are track proven as well as rebuildable.
I will say this; I have never seen anyone who was not on a tight budget choose AGX over Koni yellow when both were available for their application. Take that for what it is worth.
[QUOTE=buymysoul;2158570]A friend had KYB AGX adjustable shocks on his CRX and I was never really impressed with them.
I will say this; I have never seen anyone who was not on a tight budget choose AGX over Koni yellow when both were available for their application. Take that for what it is worth.[/QUOTE]
Yeah the shop don’t sell the yellows or else id get them.
I would ask what the AGX actually cost them and then get them to order the Yellows from Tire Rack and you cover the difference. Tell them you don’t want KYB brand shocks on your car after what happened last time. As long as they realize you aren’t trying to get any extra money out of them other than what it would cost them to get AGXs through one of their normal distributors they may be willing to do it…
I did but they don’t sell them because there not insured threw Koni company.
theyre good shocks… the reason why i said do more research is cause theres info already out there about agx adj and after all the headachs youve been through is it really worth risking it unless you match the spring rates with the proper shocks. a coilover system is the same ish expect its already matched properly you couldnt even tell the diff. what coilovers did u have before anyway
my setup: KyB agx’s with eibach sportlines set to hard, 1.5inch wheel adapters and super flush/hella rolled fenders…i love everyday driving even more everywhere i go. they are very stiff when set to hard but ALL of the “aftershock” of bumps and sh*t is gone.ya the initial bump is there but know i dont look like an idiot bumping on springs everywhere…but when they are set to soft its beautiful…but me personally i like the hard…
I had some Egays on the first month i got the car and i ended up getting some skunk coilovers after that. Don’t know the kind but they wore red if that helps. The springs i have now are the Eiboch sport-lines ones and i like how they feel minus the shocks going out.
Ride is so much better then before…
Too low! Gotta raise it back up.
Well jp. My civic is on eBay coilover and stock strut. Guess what? Rides better then my friends agx with eibach springs. Lol and all car I own are slammed. Dumped. So there’s something wrong with your car to keep hitting the tower.
hitting the tower is probably from the camber kit, since it happens quite often when people don’t get the right stuff.
i’m rocking koni/ground control, sure they were expensive but i’ll never need anything else… i think i need to replace one strut in the rear but its because all of my bushings are very bad and the RTA bushing on that side is completly torn and prob not safe at all. (replacing soon)…
any way the point is, save your money and don’t fall for the Life time warranty shit, obviously they have it for a reason as you have been back 3 times now in a very short period of time, they are doing something wrong i’m sure not to mention i’ve heard that company charges an ass load of money.
save up get some koni/gc and you’ll never look back,
looks like they threw on kyb gr2’s the second time. good stock replacement, but not really meant for lowering
[QUOTE=LoWnSlOwDa9;2159694]hitting the tower is probably from the camber kit, since it happens quite often when people don’t get the right stuff.
save up get some koni/gc and you’ll never look back,[/QUOTE]
You’re right about it being the camber kit. See the green
Ill be saving up for koni but will take some time. Thanks.
That’s exactly what they installed. The manager was shocked to see what they sold me.
