OMG the other at to mt is a effing mess its not even a write up its a clutter
we really need to put all the info on one page and one post
Mind you i got all of this on half off at Pick a Part
Stuff you need to get it going
Transmission = $90.00
Manual Starter = $11.50 (i didnt know you can use the auto)
Clutchplate = $4.00
Flywheel = $Free (they over looked it)
Throwout bearing (uhhh should come with tranny)
Pressure plate = $6.50
Clutch cable and housing = $5.00
Clutch pedal assembly = $10.50
Shifter w/ shift linkage = $10.00
Manual intermediate shaft = $8.50 (AUTO WILL NOT WORK DONT EVEN ASK WHY THATS ANNOYING JUST LISTEN)
Tranny mount = $10.00 (it was ripped)
Shift Knob Dc Sports = $Pocket item:rockon:
Dont forget to pocket some extra bolts also
if you dont know how to take something apart and put it back together then you dont need to be molesting your steering column
How Did I Cut The Hole For The Clutch Cable?: I Mounted up my manual pedals with 2 bolts, got a sharpie and put it through the hole where the cable goes and marked the fire wall (and took the pedals off duh), now take your 1 3/4 hole saw with a drill bit in the middle, burn out your drill and feel the burn in your arm… that was pretty simple, dont ya think?
Mounting Up The Transmission Mount (pic attached):
Ok it didnt work out how i wanted it to because my local lowes suck, so i got 3 bolts and alot of washers:mad:
Bolts: (M12-1.25 x 45)
Hillman flat washers: 1/2 lowes#V01018
i put a total of 8 washers on each bolt, i still had a little trouble putting the mount on but i got it on there
clear things up:
Q:
Do I need the EGR vacuums aka black box thats on the pass. fire wall? or can i remove that now?
A:[QUOTE=lksdG2;2083088]I removed my egr box and no problems yet, its been about 8 months.[/QUOTE]
Q:
Will I need a manual starter?
A:[QUOTE=integranewbie;2083165]one thing with your starter, if you go to any parts house the starters are the same part number between the auto and 5spd BUT you will need a long bolt to go through the lower starter mount point and through the 5spd bell housing to thread into the block[/QUOTE]
