Axles popped out? CHAOS at intersection!
need some expert opinion and insight…
Hit a fairly large ditch, continued driving and all of a sudden the car stopped leaned to the right a little and it felt like it was dragging something and stopped moving entirely.
Came out to find axles popped out. But before I can make that conclusion what else could you guys see from this? I didn’t really take a close look at it after having it towed away and it was way too dark.
Looks to me like the lower ball-joint broke, once that happened the only thing holding your axle in the trans is a metal c-clip… That obviously wasn’t enough to hold the axle in the trans so it popped out.
If it was just your axle that popped out, the ball joint would still be connected to your lower control arm.
definitly a ball joint, mine did this 2 weeks ago! lol
:frowning: did you happen to replace the axles as well?
Look at the teeth on the end of the axle… if they’re messed up, not only will the axle be damaged, the differential (inside the tranny) will be damaged as well. From the picture it looks like the boot on the axle was ripped as well, the entire axle is probably trash.
looks like the inner axle shaft stayed in the differential and the axle just pulled out and tore the boot in the process.
UPDATE: So went take a look at the situation and it seems as if the lower ball joint is still completely attached and if anything undamaged. Now I’m guessing the castle nut went loose and it dropped the whole knuckle and ripped off the axle.
My concern now is should I replace the ball joint or would I get away re chasing the threads and put in a new castle nut and cotter pin. I’m just trying to limp the car home if anything as well (30 mile drive) Obviously the axles will be replaced. None of the suspension related parts were damaged except my fender (wheel caved in).
this is what the ball joint and thread looked like before the aftermath (picture taken during swap):
AFTER:
i would change it wouldnt risk rethreading it
dont rethread it bro its not worth risking another accident or your life for like 50$.jus buy a new one…b safe
yeah there is no way your going to be able to bolt the nut back on anyways. just get the ball joint replaced and call it a day.
thanks for the encouraging words guys. Just picked up my new axle and lower ball joint. Now it’s just a matter of figuring out how to go about removing/installing the new LBJ with limited tools available… I’ve decided to do the driver side as well once I get the car home.
replacing it would be the easier solution for most people. if you have the chase though i would re chase it. the damaged threads are below where the nut will be so there’s no danger. you probably just didn’t have a cotter pin.
Again, horrible advice.
:rofl:
Cotter pins are my friend.
Hey! I love cotter pins as well… what I really dislike is bad advice concerning such a simple part on a car that could potentially take someones life. But hey, its worth a shot!!!
/rant
[QUOTE=unified112;2196550]Hey! I love cotter pins as well… what I really dislike is bad advice concerning such a simple part on a car that could potentially take someones life. But hey, its worth a shot!!!
/rant[/QUOTE]
No I agree lol. When OEM is less than 50 and autozone is 20, why not replace to be safe? But don’t forget those cotter pins!
I know you Colorado guys know better. :wink:
Nice build btw.
i would like to know how thats horrible advice?
everyones saying better replace to be safe? but that balljoint is not unsafe!!! the first few threads are damaged that WON’T EVEN BEEN IN THE CASTLE NUT ONCE ITS SCREWED IN!!! hell you can even cut that piece off and it’ll still be same once it’s all torqued down. but once again for some reason you’re always right because. i seriously question your mechanic knowledge and abilities.
unified112, you must bring your car to a shop just to change your wheels cause it’s unsafe to possibly not correctly torque the wheels after. do you check your own oil level or do you bring that to a shop to just in case it’s a little over or under and your not sure??
I do plenty of my own work, actually… and have no issues tapping or die’ing threads in something… but when a balljoint is concerned (ESPECIALLY with the amount of force that was on that balljoint) then it only makes sense to replace the entire unit.
True, the failure may have been due to not having a cotter pin installed… but that has nothing to do with the current condition of the balljoint in question. And if its on a lowered car, that means it has been stressed all the more. I’m sorry if you feel the need to half-ass fix problems… but id much rather be out $20 and know that there is no danger of my ‘half fixed’ job coming back to bite me in the ass.
how much pressure do you think is on that ball joint during normal driving? no more then when it was on the ground. if i tap some threads i make sure everything is perfect so there’s no half fix there it’s all legit. i guess you do have issues with taping if for you it makes it a half fix. if you strip a spark plug hole or a head stud for example, instead of putting a helicoil you’ll just change the block or head? you can do whatever you want, but don’t go around saying this and that is bad advice when it’s just a different method from yours and you’re just to scared for absolutely no reason.
btw i know it might not be the same since the engine doesn’t have to do with “safety” but the point i’m making is if you know what you’re doing and you’re sure of your work there’s no reason that ball joint can’t be fixed. if there’s loose in it or it’s 500 years old then i agree it should be replaced.
