b16 block with gsr head
Im in the middle of swapping in a jdm b16 block with a gsr head into my d.a, i dont have any issues with installation or compatibility between the two i did it to my em1 because i had a gsr head available. what i am curious about is what to do to it to optimize power with oem parts. i have a header, intake, and i stuck with the pr3 pistons and rods. i have the head port and polished but which ecu should i run, i have it converted to obd 1 if that helps.i also fabricated an itr throttle body to fit…any thoughts heres a couple pics just because… i know green isnt for everyone but i thought it looked sick in the white engine bay.
i have a some what similar set up. i would say get some CTR pistons to up ur compression. ecu p28 chipped
B16a2 block
GSR head IABs removed from the intake manifold
ITR springs/retainers REV flat faced valves
Ported and flow benched head GSR cams
blox intake manifold
ARP head studs
arospeed camgears
ITR clutch
YS1 trans
thanks for the response its helpfull when someone else is running a similar set up, i bought a pr3 ecu because that was what i was told was the easiest to work with when running obd0 and trying to get vtec. however the guy who is tuning it is booked for the next month, we ran a push button switch to engage vtec until then, i still have to break the the motor in anyway so i probably wont even use it. the manifold i got had the secondaries removed when i bought it so thats good. i found a set of arp studs for 30 bucks the guy said the hit 1100 during a mis-shift, i know that arp makes a good product but do you think i should trust them after that? if so than $30 is a steal. i have a ys1 tranny, i was thinking a b16 tranny, what are the advantages of having the ys1?also the block im running is a first gen jdm b16 a is there a difference between that and the a2?.. thank you for the insight.
some more pics
:gotpics:
its been a while since i posted anything, ive got it all in there and running, right now im running it on the pr4, im trying to locate a pr3 so i can avoid the obd1 conversion, is this a bad thing, should i just throw down the extra cash for the conversion?
she looks rough now, Im waiting untill she runs how I want then ill delve into cosmetics.
Spend the money to convert to obd1. Then get any chipped obd1 ecu (p72, or converted p28) and run either ectune, neptune or crome. Ectune and neptune require an additional rtp unit, but imo its worth it just for the real-time functions and on-board datalogging. This will not only make your life (and your tuner’s life) easier, but will make it more reliable (with a good tune) and get you more power.
Its not worth the hassle to keep obd0 and you are limited when it comes to tuning.
[QUOTE=wise_old_dragon;2224112]Spend the money to convert to obd1. Then get any chipped obd1 ecu (p72, or converted p28) and run either ectune, neptune or crome. Ectune and neptune require an additional rtp unit, but imo its worth it just for the real-time functions and on-board datalogging. This will not only make your life (and your tuner’s life) easier, but will make it more reliable (with a good tune) and get you more power.
Its not worth the hassle to keep obd0 and you are limited when it comes to tuning.[/QUOTE]
Hondata or :gtfo:
You don’t ‘need’ the RTP board when running Neptune… Once its tuned, real-time changes and datalogging aren’t a total need.
Hondata is a great system… but overkill on a fairly stock lsvtec build. I’d much rather spend $80 for Neptune and have it dialed in on the dyno before i’d pay $500+ for an EMS that does the same thing.
thats great advice, i talked to the guy who’s going to tune the car. he said if i really wanted i could keep the the pr4 and he could wire the vtec to the a.c pins(with the look in his eyes like you better convert to to obd 1 because ill kill you if i have to mess with a pr4.)with a little work. After that being said im getting the obd 1 harness and distributor locally and whatever else ill get from the junkyard. As far as the tuning program he runs crome, with the simplicity of the build i think crome should be ok? he doesnt use a dyno were going to street tune it . i think thats a better way to evaluate actual power? maybe get the parameters closer to what i need for street application? thoughts?
Street tuning works… But I wouldn’t say its better than dyno tuning.
Crome should be fine as well… if its something your tuner uses regularly, then you shouldn’t have any issues.
[QUOTE=unified112;2224132]You don’t ‘need’ the RTP board when running Neptune… Once its tuned, real-time changes and datalogging aren’t a total need.
Hondata is a great system… but overkill on a fairly stock lsvtec build. I’d much rather spend $80 for Neptune and have it dialed in on the dyno before i’d pay $500+ for an EMS that does the same thing.[/QUOTE]
This depends on if the tuner has a dealer licence for Neptune or ECtune where he can tune with his own rtp board and burn the maps to a chip to use with a chipped client ecu. If your tuner does not have a dealer licence, you MUST have an RTP board if you want to use Neptune or ecTune.
Hondata is a great platform, but overly expensive and doesn’t offer any extra features that Neptune or ECtune don’t already have.
Crome is the cheapest option (just need a chip burner, chipped ecu, and datalog cable). It works alright for what it is and can be used for most minor builds out there. There are some downsides to Crome though:
  1. constantly have to swap out chips (non-rtp) (makes tuning take 100x longer), but can be solved with a demon or ostrich
  2. Poor idle control, (hard to get good idle due to low map resolution, especially for more aggressive cams)
  3. lacks some advanced features offered in other systems (ign cut, duel maps, anti-theft, on-board code check, etc.)
  4. datalogging on crome sucks
Yup, agreed. I love that my Neptune license fee and basemap ran me less than $100 :slight_smile:
my tuner is well versed with crome. my build is pretty basic , i tried to keep it that way because its my first one. there is a shop here with a dyno and they use neptune… $800 to get on the first time and 200 an hour after that. I dont know what the average going rate for a dyno tune is but i do know im not spending a grand with this guy. my buddy put his gsr on it and made 152 after the tune and switching to e85 he made 156, im not impressed, he had already spent the 800 so this tune was only 200 but still hes got like 1200 into this guy for 4 hp. I can think of hundreds of things adding up to 1200 bucks that would more than likely add more hp, just saying. Is there any one else running on here running a b16 with a gsr head? what kind of power and compression are they making? dyno printouts? I have another 2 weeks till i can spend the money on the ecu and tune.
Yup… the software doesn’t matter nearly as much as who’s tuning it.
As far as compression, use a compression calculator. Www.zealautowerks.com Change the OEM Headgasket Thickness to .03" rather than .026" and just fill the rest of your motor specs. Done.
thanks, cool app, kinda hurt though. i guess im at 120 to the wheels about 60 shy of my goal… time to get some cams lol
I don’t know how accurate their horsepower app is, but the B-Series Compression app is pretty damn good.
Crome is fine, but outdated. Pop for something better like ECtune or Neptune. Think of it as an investment.
Without saying one is better than the other . . . think of it like this . . . a dyno is a controlled environment. Factors that would vary on the street are not taken into account, and can’t be estimated when you’re on a dyno. However, if your tuner knows what he’s doing, can street tune a car, then go to a dyno and “fine tune” the aspects he can’t see through datalogging (horsepower, torque, the relationship between the two, specific ignition timing, etc). time on the dyno is reduced, and imho, the cars done in that order run better. just my .02 based on what i’ve seen.
if ur trying to make more power. build from the block up to raise that compression first. cause if you get cams they r not gonna run properly or get much usable hp without higher compression anyway. I am also running a b16 block with a b18c1 head.
