# b16 crank on a b18 block
**URL:** <https://forum.g2ic.com/t/b16-crank-on-a-b18-block/88392>\
**Category:** Hybrids & Advanced Aftermarket Engine Performance\
**Created:** [October 2, 2009, 7:56pm UTC](https://forum.g2ic.com/t/b16-crank-on-a-b18-block/88392 "2009-10-02T19:56:12Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![jdmacuraintegra](https://forum.g2ic.com/letter_avatar_proxy/v4/letter/j/a3d4f5/32.png) [@jdmacuraintegra](https://forum.g2ic.com/u/jdmacuraintegra)\
**Post date:** [October 2, 2009, 7:56pm UTC](https://forum.g2ic.com/t/b16-crank-on-a-b18-block/88392/1 "2009-10-02T19:56:12Z")
</div>
i have a jdm b16 block complete and i was wondering if i could use the b16 crank on the b18 block with b18 or b16 rod with b16 piston and a b18 head stock just milled port match with the intake manifold i just want to know if you could the b16 crank and/or the b16 connecting rods
**Author:** ![tilegend](https://forum.g2ic.com/letter_avatar_proxy/v4/letter/t/2acd7d/32.png) [@tilegend](https://forum.g2ic.com/u/tilegend)\
**Post date:** [October 2, 2009, 8:16pm UTC](https://forum.g2ic.com/t/b16-crank-on-a-b18-block/88392/2 "2009-10-02T20:16:17Z")
</div>
you could… but you wouldnt want to…
what is your whole reasoning for it?
**Post date:** [October 2, 2009, 8:24pm UTC](https://forum.g2ic.com/t/b16-crank-on-a-b18-block/88392/3 "2009-10-02T20:24:10Z")
</div>
i was just curious but about how much compression will i gain with the b16 pistons??
**Post date:** [October 2, 2009, 8:30pm UTC](https://forum.g2ic.com/t/b16-crank-on-a-b18-block/88392/4 "2009-10-02T20:30:45Z")
</div>
> [@jdmacuraintegra;2075374](#):
you’ll loose compression due to the smaller stroke of the B16 crank even with the b16 pistons
