PRICE DROP!!! $800 NO LOWER!!!
$1200 for the lsv setup!!!
NEED THIS SOLD ASAP!!!
whats up g2ic
I have for sale my slightly modified b18a1 from my 92 integra. I have the complete original swap from my car for sale with everything from the mounts to the throttle cable to the ecu and engine harness. I am asking $800 for everything. With purchase you will receive a copy of the original title and paperwork with the exact mileage. the engine is currently in my car and is in running condition. The reason for the sale is my car got rear ended by a school bus and my insurance is only covering medical damages and not my car so I need money for a new car.
Engine runs beautifully
compression tests one month ago were 190, 185, 190, 187
no smoke of any color white blue or black
smooth shifting trans
New oil pan gasket
new exedy stage 1 clutch
new rear main seal
new valve cover gasket
new cam seals
new cam plug
new distributor o ring
new intake manifold gasket
new throttle body gasket
new injector o-rings
new IAT o-ring
new IACV gasket
All gaskets are oem honda gaskets except for the oil pan gasket which is felpro because honda couldn’t get it for me when I needed it.
Also for an extra $100 I will install a brand new timing belt and tensioner and oem honda water pump.
or for $1200 I will give you the full swap with a pr3 head that has everything except a distributor. but the distributor on the ls was already modified to be used on any b series motor. it will also come with a 22 tooth water pump and a new gsr timing belt. all you would need is b16 head studs and a new ls head gasket and the oil feed line.
the pr4 can be converted to operate vtec by the guys at xenocron for relatively cheap.
vin:JH4DA9355NS010141
mileage:140653
92 b18a1 long block (drop it in and start it up)
98 b18b1 intake manifold (slightly shaved)
93 b18a1 throttle body shaved
bare aluminum valve cover
original 92 integra header
98 integra type r oil cooler
axels and half shaft
new oil pan gasket
92 ys1 transmission
new axel seals
oem honda trans fluid used
new oem shift bushings
shift linkage and shifter
all four engine mounts
uncut obd1 engine harness
distributor
injectors
new spark plug wires
obd1 pr4 ecu
throttle cable
clutch cable
I also have the full header back exhaust I will throw in for an extra $100
price $800 for everything including copy of title and current mileage.
text me at 201 920 7867
