b18b crank, pistons, and rods into b18a?
i was wondering if its possible to put all the internals from the b18b engine block into the b18a, like crankshafts, rods, pistons and stuff. i have a b18b block but cracked because it was dropped, the internals are all still good, i have a spare b18a block with damage spun bearings and i wanna swap it into the b18a. let me know if its possible.
I know I’m not much help, but I know that they use the same rods and the piston diameter is the same (81mm) so my guess would be yes…
The only difference between b18a and b18b is the ecu, the head and cams are slightly different, other then that they are completely the same, the block is COMPLETELY the same
whats up vntec, so pretty much i jut swap everything from the b18b and bolt right up to the b18a block then right? cool…
