b18b intake mani
a buddy of mine gave me what is said to be a b18b intake mani. He says that i can put it on my a1 and gain 5-7 hp. Is this info valid? And if so can i use my rails on the mani? Thanks guys and sorry for the noobness. I’m still trying to learn:)
Yes it will bolt right up but that much horse power seems a bit much but I do believe it helps, Also I haven’t dyno proven it but I believe using the 92-93 Header and Cat will help also. The Header is designed way better and you’ll need the cat cause the headers are different lengths. Just a tip for some cheap junk yard power.
oh ok. sweet. how bout the injectors and rail?
same
Keep your injecter’s but if you get the fuel line that connects the fuel filter to the fuel rail and the fuel rail from a 94+ you can use that but there wont be any performance gains. I think it just looks better.
