B18C1 head swapped onto my B17 questions.
I have to work on my B17 head but the car is my DD. I found a B18C1 head with ITR Cams & Internals. Questions are-
  1. will my Intake/Exhaust work on the newer head?
  2. If the Intake will not work do I need a B18C intake and will it fit?
  3. Any other special considerations before buying this?
I was told that I should remove the whole B17 and replace with a cheap B18B- That way I can get the whole engine worked on. My problem is the B18B will cost maybe as much as the B18C1 head, but I don’t have funds to build the whole B17, just the B17 head. Another option is to keep the B18C1 (if this is do-able), rebuild and then sell the B17 head.
The B18c1 head is P72-2 cast…
Intake manifolds are different and NOT interchangeable.
Ok dude said he had a Blox Intake, would that fit or will it bang up against the firewall?
Should fit fine.
Nice, I’m going to check it out today, hopefully it is up to snuff :slight_smile: how do ID the ITR cams versus any others?
Throw in a B18B and do an overhaul on your B17. Don’t bother wasting your time fitting the B18C1 head to your B17. You may not have the funds to do a full overhaul now, but you’ll still have a running car to get you around.
B17 out -> B18B in -> save money -> overhaul B17 -> Unstoppable B17 back in.
Do it right, do it once.
My 0.02
Mike, remember my db2 is equipped with a b18c head :). With that being said, i checked the part number on my Skunk2 Intake Mani. (pretty much same dimensions as the Blox so it wont hit) and it is for the B18c head. Exhaust mani’s should be interchangeable n just use the headers you have. So yea it is do’able as you’ve seen i drove from Tampa to O-town n back that Sunday. When i bought the NGK blues, plugs, and valve cover gasket set i used the 97’ B18c (P72) head as the application. They say use the timing belt and kit for the water pump that you have, if you have to change it. Dont know if the guy just left off the middle timing cover or it didnt fit because of the head swap so you might wana look that up. Yea you can go 18b but id say just swap the heads if that’s what you have funds for, and that I have a prime example of the set up you can have while rebuilding your B17 head. Hit me up. If you get that Blox Intake mani n i can tell you how my Skunk is set up with-out the FITV, n how the sensors are set up that you were looking at the other day. (Member you said they made a cap for the place of that sensor on the TB)
R1
actually the b17a1 is a b16a head and intake manifolds are not interchangable with the b18c/p72 gsr head. The bolt pattern doesnt line up. So you cant use your blox b16a spec manifold on a b18c/ p72 head.
Where in this thread does it state that the Blox Intake Mani. was a b17/b16? He said he could get a B18c head from a guy and that “dude” said he had a blox intake mani. Probably for the B18c head that hes gona exchange with Mr. Avocado.
R1
I’m curious as to what’s wrong with the B17 head…
R1 how long have you owned your GS-R?
[QUOTE=db2;2207492]I’m curious as to what’s wrong with the B17 head…
R1 how long have you owned your GS-R?[/QUOTE]
Ive only had the DB2 for a few weeks now n thats how it came with the B18c Head. So I dont realy lknow what the hell the guy was thinking haha :).
R1
id do it because the b18c1 head will bump up your compression plus the blox manifold will help out alot cuz the p72 intake manifolds suck ass. id recommend getting a 2 layer head gasket if you wanna bump up your compression even more and be smokin foo’s
