b20 question
would anybody happen to know where a b20 starts to loose power after what rpm. cause i have taken my to 7.2 and i think thats a little to far. i would like to find out so i dont pop block.
all help would be nice thanks
I would stop at 6700 like a stock LS. But if your running on the track then the higher you rev the high Rpms your going to be at when you switch gears. A few things to ponder about…
My B20Z made power up to about 6800 when it was tuned. How far it will go depends on your setup. The stock tach isn’t entirely accurate either - mine shows over 7k before the rev limiter kicks in. The cams and head are the same as an LS, so it’s not going to rev a lot higher. If you really want to know how far it will go, get it tuned.
Depends on your setup. I was runnin’ a B20 with Skunk2 manifold, DC Sports header, full exhaust with test pipe, stock OBD0 computer, Skunk2 springs/retainers, SAFC, A/F gauge and larger injectors. Even with the fuel increase and “my” tuning with the SAFC, from 5000+ there was a gradual loss of torque. (engine sounded louder and kept revving but didn’t feel much faster).
And I would take it all the way to my aftermarket rev limiter at 7k anytime it was warranted.
Thats when I installed CROWER 403’s and THAT changed everything.
With your setup, if you have a stock intake manifold, I wouldn’t go higher than 7000. IF you get your car dyno’d, you can find out where exactly you should shift. My friend had a 94 civic hatch with b20b setup identical to mine (before the cams and w/o oversized injectors and an SAFC). His rev limit was i think 7300. He got his dyno’d, and his peak was around 6800. Keep in mind, we both had B20B’s with 8.8:1.
EDIT: If you have stock valves / valvesprings, I do not recommend going above factory redline. It’s there for a reason. Honda non-vtec engines usually die in the heads
90medblu…how did you like the 403’s? im thinkin of re-buying them cuz i bought a b16 head but now figured its gunna cost to much for a fully built ls/vtec so im goin with b20, my jdm s1 trans and some 403s…but did you notice a big difference
