i set int 006 ex 008 it seems to take lot of cranks to get to 190 psi could my valves be to tight . my plugs are a little bit black now they were brown before i put in cams cant seem to time it with light either marks no were near close runs good still thinking bought trying v tec on my block
What are the cams just a factory replacment? Also if they are aftermarket cams they usually have different valve lash settings. And lastly what motor
the cams are aftermarket regrinds primary int 278 adv dur198 @.050 .430 lift sec int 264 adv dur 192 @.050 420 lift exast 276 adv dur 196 @ .050 .405 lift and the motor is a b20z bottom and stock 1.8 non vtec head i bought the car this way the flyweel was lightend and it has as header and intake
