B20b head on b18a1?
thinking about buying this sedan but worried about the motor. Its a 91 b18a1 with a b20b head, what is the advantage of this? Also would the obd need to have been converted? I need this thing to be able to pass emissions.
apparently not much of an advantage:
http://www.g2ic.com/forums/showthread.php?t=197521&page=5
post #91 and on.
Less power!, lower compression.
It is probably a P75 head which is the same one as one on an OBD2 Integra (would probably flow a little better than the stock 91 head… but you probably wouldn’t be able to tell much difference). If they did it right and swapped any sensors that might be different between the OBD0 and OBD2, you shouldn’t have any problem. It should still be OBD0. Just make sure that the check engine light comes on when you turn the ignition to on and then goes off after the fuel pump primes and stays off when running and you should be good to go.
umm… no. A P75 head is not going to make less power or lower compression - compression should be the same and it might make a slight amount more power. I don’t think a P8R head would either (might even raise it and make more power), but it’s very likely that it is a P8R, so I’m not even going to go there.
