One of the pulleys on the car down below the bottom right hand side of the valve cover isnt moving. The belt is joing going around and around and burning up and the pulley isnt moving. I can feel a hole in the side of the pulley, is this a hex shape or just a circle? I think a bearing mighta went bad…any tips?
i believe you are talking about your ac compressor, since you can still have your power steering. I believe it is a circle, and most likely that your compressor locked up which happens with age. Either you can cut the belt or let it strip itself (prefer to cut), its up to you if you really need ac get a new if not let it go. My opinion is AC slow hondas and acuras down so much i dont even use mine.
