but i kno if has something to do with the ign. sometimes i giggle the key and it works but now it only comes on (radio) when key is in the acc position. so do i replace the ignition or can it be repaired please lmk. thanx for the help in advanced…
blower motor and radio not working. fuses are good btw.
Your ign. switch is worn out, it will need to be replaced, not the whole thing just the switch itself, it can be removed by removing 2 retaining screws holding it the the ign. switch housing, and unplugging the other end(s):sipread: 94
