After driving to work this morning, I was smelling antifreeze. There was none leaking but I heard a strange noise under the hood. When I popped the hoid, I head fluid boiling in the coolant resovoir. Not the radiator, but the plastic resovoir. Do I need a flush and fill? Has anyone heard of this?
I had a similar problem.
It started when my car overheated one day after idling for a long time (parked). When I checked the coolant, there was none!!!. No puddle under the car or anything either. I refilled the Radiator, and checked for leaks. Found none. Been checking the coolant for almost two months now and haven’t lost any.
For a few days after this happened, Whenever I would get where I was going, I would hear the Resivoir “bubbling”. Not sure if there was air trapped in the system or what.
And I STILL can’t figure out what happened to the coolant in the first place!!! ![]()
sounds like your radiator cap is not holding pressure…replace you radiator cap…I had the same problem with my LS and after I changed the cap it never did it again
