Ok, so I plan on boosting my Integra. As of right now it has a stock B20 swap. I do not plan on tearing the engine apart other than pulling it to change out the rod bolts (and possibly bearings, rings and a slight hone) My B20 only has about 18K miles on it, other than replacing the rod bolts should I go the extra distance just for 7psi?
I also plan on buying a Full-Race kit. I need some help with choosing the correct A/R for my setup, along with cams and possibly injectors. Along with the Golden Eagle Fuel Rail and FPR. Braided SS Fuel Lines and if necessary a Walbro Intank FP (which size 190lph or 250lph). Back to injectors I know I can go with DSM 450’s, but do I really need injectors that big, I am also aware if i get too large of an injector using Hondata S100 I can tune the injectors down. As far as an EMS I plan on Hondata S100 with Boost option, along with an OBD1 conversion using a P75 as they are really easy to come by.
Goals: Daily Driving in Arizona, 92 Octane, 300 HP (if possible…), I’m shooting for maybe a 13 sec. pass on slicks…
Cliffs: Need help with choosing correct A/R for the T3/TO4E on the Full-Race Kit (.57, .60 or .61), correct size Injectors (RC - 310’s, DSM 450’s), Correct “turbo” cams (Crane, Crower…), Fuel Pump (Walbro 190 or 250),
Do any of you have any suggestions for my future setup. I realize there are a few things I have over looked. Please help me figure it out.
A friend of mine is running 14psi on a BONE stock B20B in his EH2. He runs VERY low 12s (like 12.04 at 120+ mph) with slicks. He drives it daily and even delivered pizza in it for nearly a year. He isn’t easy on it at all, and it’s held up so far.
If you’ve got a B20B I’m sure it’ll have no problems handling 7psi stock. But good luck getting 300whp out of it.
I’ll ask him the specifics of his setup and get back to you.
these are pics of my man mikes hatch that is running(the guy in question). he is the one who convinced me to run a stock b20 setup and i am on a turbonetics t3/to4e 60/63trim on 14lbs daily. so dont say it can be done.
Makes me wanna get a B20B very hard to find over here in New Zealand. My g/fs dad imports stuff from america might get him to find me one do you guys know what these motors sell for a round about price?
Nice car… But those numbers are way low for 14psi on that engine on that turbo… Unless you have timing pulled majorly back. I would expect numbers like that on a mustang dyno on street simulation. Not to mention that 145 compression is 20% lower then the others which is really bad. Prolly where your power loss is coming from.
the 145 compression is recent. The first dyno of 267whp 225wtq was on a 90+degree day on the ocean front. Also the second dyno i ran on was reading low for everyone that day because he had it set to be corrected for ohio and was in virginia. As well as the fact that i have a very conservative tune.
