Was just wondering what type of brake rotors and pads you guys are using, im in the middle of a project and need to upgrade my brakes, not looking to spend a ton of money but want something that looks good and will be good for street, will upgrade calipers later if I decide to race at all. Was thinking about the password jdm rotors with hawk pads.
nice, suspension and brakes are always the most important part… imo. id go with password jdm cross drilled and slotted rotors, they are pretty cheap, then id get hawk street performance brake pads, and some stop tech stainless steel brakelines
Cross drilled and slotted rotors are a waste of time unless youre upgrading to a big-brake-kit. Stick with an oem-sized blank rotor and get a good set of pads with stainless brake lines and call it a day.
who cares, they look cool
eyeroll
when it comes to brakes, it’s all about looks! you’re right!
^^^ lol. i had ebc slotted and dimple with green pad they were pretty. now i have the wilwood even bettr. depends what kind the driving you do and select the right set up
Yes, I am sure he realizes they are important, thank you for this information. :rollseyes:
Crossdrilled rotors? ROFL. Please, stay off
+1 this is what I would do.
If you have extra monies get the Legend capipers and bigger rotors. Regardless, stay away from cross-drilled.
I dont see an issue with drilled rotors as long as it is with a (reputable) Big-Brake-Kit. Rotors that were made with drill holes in them. Definitely dont buy blanks that have had holes drilled… That is a recipe for bad news for sure.
With a big-brake-kit, you are increasing the surface-area of your rotors… So when you have cross-drilled big rotors, you should still have the same amount of surface area (if not more) than stock blank rotors. But if you stick with an OEM sized rotor and they’re drilled… you’re decreasing surface area which is going to make you have to push the pedal harder to get the same braking force… which is going to eat your pads up.
The cheapest, best bet for brakes… Buy a good blank rotor, a good set of pads, and a set of stainless lines. The Legend calipers and bigger rotors is always a good upgrade as well, but can get spendy.
FWIW, I’m just rambling lol.
could also upgrade ITR brakes… provides better than stock braking power.
I’ve got ITR brakes w/ 11" cross drilled/slotted rotors
legend front calipers, 50 bucks for the pair at a junkyard
'95 Prelude front rotors redrilled to your bolt pattern, 100 for the pair and the machining, maybe less, depends.
so thats the front. for 150 bucks id rather have 11" rotors and 2 piston calipers than some shitty OEM sized setup with a set of drilled rotors that WILL crack and warp for around 80 bucks, and then 80 bucks again everytime you crack a rotor, which you will do.
with blanks, you just have them turned at a machine shop for 20 bucks and youre back on the road.
you can do the same thing with the back using EP3 civic rotors and DC5 calipers, and would probably cost another 150ish dollars, for around 300 dollars, 400 at the most (with stainless lines and pads) you are essentially getting 11" rotors all around, and much better calipers on both ends. AND the shit will last WAY longer and be WAY cheaper to maintain, all the while stopping you better than any OEM DA sized rotor/caliper ever could, drilled or not. more surface area on 11" rotors means more friction which means more stopping power, no matter which way you slice it.
cross-drilled rotors only work on brake systems that were designed for it originally. two-peice, veined rotors on big heavy luxury cars helps with initial bite when brakes are applied, the initial surface gases are expelled more quickly right after you press the pedal with slotted-drilled rotors, but the chance of cracking and warping them is much greater, especially when driven spirited or at a racetrack. even the big luxo cars that are designed with drilled rotors have cracking issues when driven hard for extended periods of time. they just dont hold up to the heat cycles.
so 300 dollars all around and you pay that once.
or 210 dollars for drilled rotors and new pads, and another 80 dollars everytime you have to replace the rotors, it takes one set of rotors to put you over the cost of a whole 11" setup all around.
drilled rotors also scream “steal me”. just another visual cue for would-be thieves. keep it simple, keep it clean, keep it safe. dont buy drilled rotors.
edit: LOL i just looked up the price of those PWJDM rotors. FUCK that shit. 150 bucks, a couple times when you crack them, for rotors with holes drilled in them, or blanks for half the price and only one time purchased… it IS cheaper to do the work and get the 11in setup. no doubt about that now that i see how expensive them shits are LOL
remember, everytime you replace the rotor, youre supposed to replace the pad and bed them in properly too…
Very true… No quips with your post at all.
But, how many people here really need more stopping power than stock? Sure, the 11" rotors look good behind some nice rims, but its not an essential thing.
Though if you have the dough and nothing better to spend the money on… It most definitely won’t hurt.
hmmm. so legend calipers will bolt right up and be in the correct placement for the 11" rotors right from factory?
and to be fair, it’s not the size of the rotor, but rather the actual contact and piston area
i would just go with a fr. brake upgrade. by doing the the backs, you are increasing the rotating mass and increasing unsprung weight. it’s definitely not a fair trade in a fwd car, IMO
If I recall there is some slight grinding that needs to be done on the calipers… but I could be wrong.
hmmm yea, in all honesty, stainless lines, decent blanks, and hawk pads and you’re pretty much GTG. when i threw my hawks on, it was like night and day.
i was more giving a reason why NOT to get drilled rotors, as the money one would spend to maintain drilled rotors would be greater than even an 11in setup at all four corners.
not that what i suggested should be done, just what could be done with the same money.
i neglected the grinding issue, but thats peanuts compared to 150 dollar rotors every 4-6 months.
Understood. Valid information for sure.
coolio. dollar for dollar, they definitely are some decent upgrades on the cheap if someone did feel the need
i’m swapping to 4x114 and was gonna use the prelude rotors down the road, but with 98+ itr calipers. wasn’t aware the legend 2 piston calipers could be utilized and probably for cheaper to boot.
thanks for that link, unified
for sure, if my brembo blanks/goodrich line/hawk pad combo didnt try to pull my face into the windsheild every time i stopped, i would be looking into a bigger setup.
when i finally turn the car into a honda challenge contender, im probably going to do it for the long-term fade resistance. not that there is a horrible issue with fade now, but give me 6-10 laps at roebling or road atlanta and you can cook hotdogs on my faded pads, i actually caught the passenger side OEM pad on fire during my first track event, running Motul RBF6000 on stainless lines and OEM rotors/pads. my friends say it was quite the sight. had to replace the front tires and passenger fender liner lolol
no more derail, back to the OP.
