buying new tires
im going to be buying my first set of brand new tires in my life soon. if someone could help please explain as simply as possible what all the numbers are for and what the best size would be for a daily/spirited driver…
as far as i know the last number means the size of the rim. im going to be getting 15in rims when i get the tires…
ok well my car is lowered about 3in. so ive got 205 50 r15. Which means 205mm (width of rim) 50(height of tire sidewall) r15 (size of rim). so find out what the width of the rim is. Take it to a tire shop if you have to, they will help. If its not lowered dont make the sidewall size too small or it will ride rough. And your right the r15 or whatever number means the rim size. hope that helps
Link Very first choice, click on it. Now that gives the break down of what everything on tire means. You still need to provide us with: camber adjustment capabilities, money available to spend, height of vehicle/drop, rim width, how many miles you want to get out of the tires, do you plan on driving on these year around, do you care about wet traction that much or are you ok with going slower when it rains and watching for puddles and such, brand of sleeves/shocks or coilovers?
since you are getting 15" rims your best bet would be 205/50r15 tire size. you may get away with 195/50 (slightly smaller than oem diameter) or 195/55 (slightly larger than oem diameter) if you want a lil extra drop get the 195/50s or the 195/55s if you want a little smoother ride because of more sidewall. the 205/50s are the closest overall diameter to the stock 14" tires. the first 3 numbers ie 205 means the tire width in millimeters. the next 2 is 50 is the aspect ratio that the sidewall is to the tire width, which means that the sidewall would be 50% of a 205/50r15 tire. and obviously the last number would mean the rim size.
great link here http://images.google.com/imgres?imgu...%3Den%26sa%3DN
[QUOTE=darnizzle8805;2154403]since you are getting 15" rims your best bet would be 205/50r15 tire size. you may get away with 195/50 (slightly smaller than oem diameter) or 195/55 (slightly larger than oem diameter) if you want a lil extra drop get the 195/50s or the 195/55s if you want a little smoother ride because of more sidewall. the 205/50s are the closest overall diameter to the stock 14" tires. the first 3 numbers ie 205 means the tire width in millimeters. the next 2 is 50 is the aspect ratio that the sidewall is to the tire width, which means that the sidewall would be 50% of a 205/50r15 tire. and obviously the last number would mean the rim size.
great link here http://images.google.com/imgres?imgu...%3Den%26sa%3DN[/QUOTE]
You must be bored… I have everything and more in what I posted above you. Must not have clicked on that read thing that says “link” or even read what I wrote. And to say your best bet is is pointless, since you dont know anything about what he has or needs. I am about to run a 225/45 on mine, and currently running a 215, so a 195 being my best bet would be way off…
Who cares, it all got explained either way, and the info is here now for (smart) people to search. Aren’t you running 16’s on your car anyways? For a 15" tire on our cars, it’s either 195/55/15 or 205/50/15 to get to the original diameter.
Again he didnt ask for something close to the original diameter. And yes even with 15’s he could run 225’s easily with the right stuff. That is why I ask what all did he have done… And with what I wrote it went into much greater detail.
Say for instance he has some no name coilovers slammed on stock shock. Tires is far from what he needs to worry about for spirited driving. I am tring to give him the best possible advice for what he is wanting, since from his post, seems to be slightly non-informed on “sprited” driving if he doesnt know what the stuff on the side of his tire equates to. Which is fine, and I have no problems with. Jus trying to get all his info and guide him in the right path for spirited driving enjoyment.
