Can I boost a motor with Crower 403s?
I have a b20z with a P8R head (the head has Crower 403s)
Will these work against a turbo? Or might they help?
I am thinking of turboing my car, but after I just built up this head, I’m not sure I want to take the cams out.
might have to much overlap and blow aome air out the cylinders but i dont know someone else with personal experience will help you
so its possible that the turbo could push air into the cylinders when both intake and exhaust valves are open, and then just force it out the other end?
hmmm
yes if it has too much overlap, the cam is a all motor profile but im not sure how much overlap it has
they will need extensive cam gear tunning but, you will be able to make power well past 7k.
what about using something like Hondata?
