will it work? i found one in a local junk yard, they want 150 for it.what should i grab from it when i take it out?there is also a turbo from a datson which one would be better? thanks
You mean from a Mercedes Turbo Diesel?
i think so
It’s a diesel turbo, not meant for gasoline motors…
doesnt, the turbo just suck the air from the motor,its not powered by desiel, can you tell me why it wouldnt work…what about a datsun turbo z?
No 5hit turbos are not powered by fuel, they’re powered by exhaust gases. Diesel motors create lower exhaust pressures than a typical gasoline engine, that’s why there are diesel specific turbo components.
The datsun turbo was designed and manufactured in the early 1980’s and a lot has changed in that time. The Datsun Z’s were also 6-cyl (280ZX was I6 and the 300ZX was V6) and would not be a good match for your engine.
just spend like $250 and buy yourself a used turbo off of something you KNOW will work. Dont go raping parts off of misc cars and trucks because they’re cheap.
id say chances are the flanges wont hook up to what you have
