Can't decide on the right size rims! Please Help!
I Can’t decide on the right size rims! Please Help!
I like the way 17 inch tenzo R’s look but, some one said
because I had the car dropped an inch and a half they’ll
rub. Will they? Help!
They shouldn’t rub with the proper offset. I have 17" Fondmetals with H&R Sports. My drop is 2"F and 2 3/8"R.
my car is pretty much slammed on 17’s…but not a good thing cause you go through tires…but you said your only going a inch or so…so yah 17 by 7 inch rims with 205/40’s will fit just fine…they’ll tuck…well mine do, but if your tires wear like hell set your toe to zero and get a caimber kit…specialty products does well. thats what im getting…and i still need to set toe but yah…i stop now
Old School 15’s :up:
i think if you are going to go show just get some 17’s but if you are more into the race get some 16 or 15 i have some 16 inch cpr sprints
Get 17"s… no problem… I had 17"s with my coils slammed no rub… boucy as a muther though… also check out this place cheapest rims I have seen…
www.street-trendz.com
Originally posted by cdup
[B]Get 17"s… no problem… I had 17"s with my coils slammed no rub… boucy as a muther though… also check out this place cheapest rims I have seen…
www.street-trendz.com [/B]
those prices are pretty good. but www.whalentire.com has a better selection and better prices (well, it depends on how expensive of tires you want w/ your combo).
Depends what you’re into bro… personally I wouldn’t get 17s again (unless they were light) Think about how much money we’ve all spent on a cold air intake/header/full exhaust/pair of cams/ECU (VAFC) etc… now do you really want to kill HP with heavy rollers??
