Ya, me and my friend are rebuilding his car, and i’m trying to get the axels out. I got one side out with ease and now the other side, the dam axel is out of the tranny but the only thing left is the tie rod. I took the bolt off and tried to hit it loose with a hammer and it’s not coming out. Of course the passenger side comes out easy and this one doesn’t. I don’t have that tool to pry the tie rod off. So do you guys know of anything else i can try??? PLEASE!!!:mad: :mad: :mad:
Leave the nut on the threads and lower the wieght of the car onto that bolt. It will come loose. Thats how I did it before I bought a tierod puller. Best of luck, and I think this should be in the help section next time;)
HEY SHENRIE
Well basically the reason i posted it here, is because it is not an Integra that i’m working on. Another thing is that i have all the rest of wheel assembly already disconnected and i can’t connected back up because we had to cut the bolts out. I don’t need the bolts anyways because we have another scrap car in which were using the wheel and axel from. Will it still work if everything is all disconnected??? I REALLY APRRECIATED THE HELP!!! THANKS!!!
