heres my post for h-t. we did the things they suggested allready… here thanks ya’ll http://www.honda-tech.com/zerothread?id=991269
try bleeding your coolant, somthing causing the car to high idle when air bubbles are trapped in the coolant…there is a bleeder screw that you need to use, but i cant remeber where it is…
really, hey if you could describe to me where it is, it could help me alot, but thanks alot !
http://www.g2ic.com/forums/showthread.php?t=42969&highlight=bad+idle
follow these instructions and everthing should be ok. it fixed my idle problems 3 times.
Yeah try that too, but heres a thread on that bleeder screw, run a search for more…
http://www.g2ic.com/forums/showthread.php?t=35395&highlight=coolant+bleeder+screw
