ok, so yesterday i did the FITV and IACV adjusting and cleaning, i also removed the throttle body and cleaned it, but the gasket broke, so i went to go get a new one, but the store didnt have any, so i got “form-a-gasket” for temporary fix till i get a gasket, i dont believe this is the problem though, the CEL is on and the code it is throwing is 5 slow blinks, which mean 50 right? but there is no 50 on the list of codes in teg tips, what could the problem be?
is there a pause in between each slow blink? it could be just code 10 as it cycles through the codes?
no there is no pause, i believe i figured it out, i think i read it wrong, its actually a 5, which is the map sensor, so i took the TB off again, and it turns out that i plugged the hole that the MAP sensor vacuum line plugs into with that “form-a-gasket” stuff, now im trying to find a real gasket, not an easy feat.
ahhh fun stuff heh heh let us know what you exactly figure out
ok, made a new paper gasket, car is running good now, but i went out to start it this morning and the idle wasnt as high as it used to be when its cold? is this bad? could it have been caused by either the IACV or FITV cleaning/adjusting?
Did you screw the fitv adjuster all the way in? If so, try backing it off a bit.
yes i did, i will try that, thanks for the help
