Ok guys I have searched everywhere trust me so any help is greatly appreciated
I bought this integra for reall cheap from a guy who told me he took it to 4 mechanicks and they couldn’t figure out what his problem was
The car has 90000 miles on and idles fine, no cel, and revs up ok might feel a lil slugish.
Here the problem driving it it is extrmely slow, when I say slow I mean I can ride a bicycle faster , it feels like something is holding it back extremley…I figured it was a cloged cat so I took the cat off and it made no difference at all…checked the timing also and everything was perfect…new spark plugs, wires, cap and rotor, fuel filter and it recently got an oil change…car is 100% stock stock stock…I am deff stumped any help is appreciate thanx a head of time
when i baught my integra it sort of had the same problem. it was really slow and lacked power and acceleration. my problem was the plastic intake tube had a huge crack in it. i repleaced the air filter and the intake tube and it worked fine. i also came to find out the fuel tank had alot of dirty and gunk in it, i cleaned that out and it helped even more. im no mechanic but thats my thoughts. change air filter, check for cracks, check fuel tank for gunk, and also try running some sea foam threw it.
Well its deffenetly not the plastic intake because I removed that to get to the fuel filter easier and no difference, but the gunk in the fuel tank is a good try how did u clean it out if you don’t mind me asking
ohhh ok. i removed the tank from underneath the car and ordered these cleaning “chemicals” off a website. i dont remember exactly the name of it but i did some research on google about cleaning out car fuel tanks. it really sounds like you have a fuel problem either something in the tank or the lines or the injectors, maybe the fuel pressure regulator is bad. im not sure but if 4 mechanics cant figure it out then its probably something pretty complicated and not seen to often.
ok so i tried to clean out the tank of any dirt or rust and nothing it was perfectly fine…even the fuel pump filter was nice and clean…any one have any other ideas…could a bad fuel pressure regulator cause this???
Im sure that other mechanics checked but, what is the fuel pressue WHILE DRIVING. It might be fine just sitting there or when you stab the throttle but if it isnt good during driving it is most likely your fuel pump. Its a pain in the ass but sometimes its the only way to check certain fuel issues. When I worked at the stealership I had to heck a couple vehicles this way to determine a bad fuel pump.
:werd: Yea make sure the car has good compression. But then again I would think that the mechanics have checked the compression. Damn if 4 mechanics cant tell then fuck man thats nuts. Hmm that is wierd. Good luck man.
No one is outright telling him to replace the 4 injectors because throwing parts at a car thats not running right isnt always going to work. That’s just my .02!
I agree with the others and say do a compression check, and if you have access to a fuel pressure tester, definitely check the pressure while driving.
After that I am stumped.
Yeah man, thats real shitty… i’ve been trying to diagnose this same problem for almost a year. i went out and bought a whole distributer from vatozone, and it seems like its worse, i trying my fuel injectors next, if u happen to find out whats wrong post it, so i can see if its something i havent done
[QUOTE=masshole;2084676]No one is outright telling him to replace the 4 injectors because throwing parts at a car thats not running right isnt always going to work. That’s just my .02!
After that I am stumped.[/QUOTE]
agreed, especialy since the price of 4 injectors would be half of what the OP paid for the carand FYI a faulty fuel injector will most likely throw a CEL.
Just Curius, Are you 100 percent sure that the motors slugish. have the brakes been check to make sure that they are not draging in some way. I.E. a frozen brake caliper.
If you are sure, I have to agree and check compression and maybe even do a leakdown on the motor.
one of my first test was the compression test…all 4 cylinders were at 160psi on the dot perfect i think…looked at the brakes and no frozen calipers…good i dea though…i just gotta get a fuel pressure guage and see while driving…i did pull the injectors off and there not leaking and spray reall well…im thinkin either my fpr…or my fuel pump…its getting kinda cold out here lately and i been workin alot hope i can get a chance to do this soon!! thanx for all the help guys…any other ideas are appreciated
yeah man just keep troubleshooting and dont give up, someone else has definitely ran into this problem before… ive got new calipers all the way around so i scratched that one off the list. Are u sure a bad injector would throw a code considering it recieves an input signal from the ECU and it doesnt send one back on an obd0 car? Someone correct me if im wrong plz…
yeah i was thinking about doing that too. i wouldn’t suspect my ecu going bad, never had a cel , i reset it and the car was running about the same, What usually goes bad on an ECU
Update, i was going thru some old posts on here, and stumbled across the seafoam thread,… figuring i had nothing to lose i tried it… and it fixed the problem:werd: So it seems the more mileage a motor has, the more likely the valves are to stick. car runs like a champ now:rockon:
