ok, so the other day i parked my car in the garage, at that time everything was fine, i went out last night and started it, it idle’d at the very first RPM line and was bouncing a little and the lights were dimming with the rpm drop, after a few minutes the CEL came on and the RPM went up to 1500, but the car was still not running right, the rpm’s werent really bouncing anymore, it just didnt sound right, so i let it warm up, and then shut it off, and turned it on again and it did the same thing with the idle really low and then the CEL coming on and everything, i was just dumbfounded, and i have no idea what could have happened, its just sitting in the garage, granted it has been REALLY cold, so it must have something to do with that, so what could the cold have fucked up? thanks in advance everyone
well your first step would be to retrieve the check engine light code.
and how do you go about doing that, the light just comes on and stays on, no flashing, no nothing…
nevermind, looked in the teg tips, will have to check later, as i do not have access to my car anymore, but also, how do you “jump the connector” i know it says look in the haynes manual, but im poor and cant buy one
so thanks anyone
You can use a paper clip if you don’t have anything else handy. Then just read the number of blinks (looks like you read the Teg Tips, it explains it in there). If you don’t have a factory manual, you can find one (FULL factory service manual, not that haynes/chilton BS) with a little time on google :read:
awesome, thanks man, ill get the code(s) and get back to everyone!
