not really familiar with G2s. i have a question about the cat converter or a test pipe. i was wondering if there is a difference between the ones made for a non-vtec and a v-tec model…as in the flange that bolts up to the downpipe? can anyone shine some light on this?..and length wise.
There’s no difference between vtec and non-vtec.
Your cat bolts to the header with a ball style flange which uses a donut gasket. This allows the exhaust system to move independently of the header to reduce possible damage. The only thing you need to worry about is the size, some headers will have a larger collector than others and thus a larger donut gasket.
Your cat bolts to the exhaust with as standard flat 3 bolt flange. Again, diameter of the piping will differ depending on the exhaust you’re running.
Other than that the only thing you need to worry about will be the length, that will be dependent on the header you’re using, the exhaust you’re using, and the car it’s all going on.
For reference here is the cat I made for my build:
^^+1 to everything he said.^^
Well, except for the homemade cat. I didn’t do that.
thankx collin, in not too worried on the length because im going to have a shop fabricate everything behind the cat for me. i only asked about the ball styled flange because they are different on the 3rd gen tegs. and i know more bout them then the 2nd gen tegs…thanks for the help.
now, time for me to go find a cat or test pipe! haha.
How are they different on the 3rd gen? You can put newer headers on older cars… the only difference is the length not the flange style.
well, from my understanding and i actually tried it…its how the flange sits…or more like angled. i tried to put a b16 header on to a ls and the flanges didnt line up…the flange on the header was opposite from the one on the cat…correct me if im wrong though.
Hmm, that’s odd, my understanding was that all the b series headers were the same regarding that flange, only difference was length. Some pics would definitely help.
Either way, if you’re having a shop do the install then the whole question is moot anyway as they’ll just fab it to work with whatever is already on the car, they will change lengths and flanges accordingly.
