On a PR3 ecu can you get a check engine light from any internal problems like bad compression? I just put in new piston seals and I got a little rev happy before they seated properly and now I’m getting a check engine light.
No.
check what error code it is giving you…
leeo
I would check the code but I’m about 2000 miles away from my car until Friday. Is there a site that has a listing of the different error codes for pr3 OBD 1 ECU’S?
OBD1 PR3 ecu codes are the same as 92-95 GSR’s, 94-95 Del Sol VTECS, and 94-95 Prelude VTECs.
