Clunking noises!
Ive been hearing clunking noices coming from the rear of my car. It occurs whenever I realese the accelerator (Gas Pedal). It clunks twice. It is a very low-pitched sound. Does anyone know whats the problem and know of a solution. Thanx…
Re: Clunking noises!
you might have to be more specific.
one farfetched idea… when you acelerate you start throwing a lot of exhaust out, making your whole exhaust piping rock back and forth (thus the purpose of rubber hangers) and you also put out a lot of vibration.
If you ever rev your engine up hard, and have someone look at your exhaust tip, they’ll notice it rocking back and forth when you accel.
Sometimes your engine will just move around when you accellerate, and it’ll rotate back and forth… this will make the exhaust pipe rock back and forth too.
I think it might be your tailpipe banging against your shifter, or heat shield if that’s still on, or it could be something totally different…
check it from the outside and see if your exhaust piping is banging on anything.
