I’m doing a b16 swap into my 91 integra, and the tranny that the swap came with is a YS1, i understand the the input shaft spline inst compatible with this tranny, so I’m here to ask what clutch assembly do i use? 92-93 integra? are those the same has the 94 and up hydraulic clutch assembly’s?
youse a 92/93 to be safe i think ithe only different of 94 an up was the pressure plate was stiffer i think but im sure some one will clear it up
i believe the release bearings and the other bearing is also different…
since I just answered basically the same thing in another thread… http://www.g2ic.com/forums/showthread.php?t=202279
Thanks alot guys, i just bought a exedy clutch kit for a 92-93 integra so that should solve that problem. now im wondering, for the obd0 to obd1 conversion i will only need the ecu jumper and the distributor wiring adapter?
Thank you, i really appreciate it. Time for my project car to be completed :rockon:
