clutch slipping @ high rpm
my car shifts fine normally, but then say im in third or any other gear for that matter, it kinda goes but then just starts to rev. this is horrible and means i wont be driving my car hard until i figure this out. i have a clutch masters stage 3 installed a year ago, this problem occured after i burnt the clutch a little to pull my car up a curb in reverse. . . im a little worried. . .
hmm…try adjusting the clutch cable…try screwing it up twards the hood of the car a few turns…it may make the pedal feel a little different the it worked for me…hope it helps.
later,
Dan
thanks man, i hope this works, ill ge tback to you on this.
If adjusting the clutch didint help then you most likely need a new pressure plate…good luck
tightened the cable and the car now drives like a dream. but i got into a accident last night unforunately, the night i put my new rota circuit 8s on. . … sigh. . . nothing big, broken clear corner and gashed bumper. maybe this might help me out in a way. . .:naughty:
