Cold Auto HelP!
WHen my auto is cold. in drive, it acts like its in low. it wont shift! But when it gets up to operating temp, where it usually sits, its fine. someone please help! Thanks alot!
I used to get the same thing too sometimes…it’ll stay in 2nd for a while, and then finally shift. I just make sure I warm my car up properly in the mornings. Never had a problem since.
Whew! Thanks alot. I hope thats all it is, but it was worse comin home from work tonite, it lasted alot longer. usually as soon as it gets up to temp. it shifts fine. but it stayed up bout a mile or so and then shifted. should i be worried? But i am gonna start lettin it warm up in the mornings now
Just give your teg a 5 minute warm up before you drive it the first time each day during the winter. My teg and my subaru do the same thing on cold days.
Ok, but when youd come to a stop, did it act like it was gonna die?
No, it never died, or came close to it… that might be somethin that your tranny though… (idle speed??). Anyway, let us know if your problem goes away after you warm it up good.
Ditto to what Integra Pilot said.
Well its warmin up now. im leaving for school in a few minutes, ill post up later how it did. wish me luck! :slight_smile:
It did it again. but not as bad after it warmed up a lil. im gonna chek the fluid level too. just in case. i hope !
isnt it supposed to do that??
its supposed to warm up ur car better while ur driving…
my dad drives a 1.6EL and its a feature listed…
