I know this has been covered a 100 times before, but I had my crossmember off today and a Comptech header, so I took the opportunity to take a pic of it on the car. For reference, the Comptech header for the DC integra is right at 9 inches too short for my car… I had 2 inches welded into my mid pipe, so the DC header is ~11 inches too short to fit on a 90-91 Integra and should be about 9 inches too short for a 92-93 (if my assumption about the 92-93 is correct.
The header is also clocked differently from the DA cat… you can see it in the pic, but an aftermarket cat could have a rotating flange to take care of that problem.
And let me say… the fit of the Comptech is BEAUTIFUL compared to my cheap POS ebay header :lol:
For searching: header Comptech Integra 1991 1992 1993 1990 1994 DC2 DC 3G
quick question you said you put a header from a DC integra on a DA i bought a header from a DC its a 4-1 and i read it would fit but when it doesnt fit do only a 4-2-1 from a DC fit on a DA?
I would imagine you will run into thee same problem I have pictured… the header will bolt up, but it will be too short. I have not heard any other reason why the DC headers don’t fit… regardless of design.
The JDM 4-1 headers have a 2.5" collector… so you would have to have a bigger cat to fit the JDM header…
Are you sure you can’t index the cat to make it line up? There are three nuts and bolts that hold it on at the rear. You shold be able to turn it 120 degrees for each bolt hole moved. It would take a muffler shop about 10 minutes to fab a adapter pipe.
good info to know.
personally in the past i’ve just always had all flanges cut and just have everything welded into place, with least amount of joints possible. now yes this does make it a pain to replace pieces but its cleaner looking and end up with less joints and possible leaks
You can possibly clock the cat… but I also know an aftermarket cat would work just fine because the “direct replacement” type cats from Magnaflow have a donut flange that isn’t actually weloded in place… it can be turned freely into any position…
