ok its burning coolant in the cylinders while driving and start up. head was pressure tested and resurfaced before install, new but cheap head gasket, does not over heat while driving, block has 245,xxx miles and was most likely over heated by previous owner, bleeds coolant into the cylinders when sitting over night…
anyone have any ideas or insight what this could be? thanks
[QUOTE=integranewbie;2092285]ok its burning coolant in the cylinders while driving and start up. head was pressure tested and resurfaced before install, new but cheap head gasket, does not over heat while driving, block has 245,xxx miles and was most likely over heated by previous owner, bleeds coolant into the cylinders when sitting over night…
anyone have any ideas or insight what this could be? thanks[/QUOTE]
Possible head gasket. Try pressure testing the cooling system again and c what happens. Another dude on here had a cheap head gasket put in and it leaked.
i know its a cheap gasket and probably isnt helping any but i got thinking that since its not over heating the head gasket cant be leaking cause the cylinder pressures and heat would blow into the cooling system, causing it to over heat fast and also lose coolant etc.
i figured it out. its the intake manifold gasket. its leaking where the coolant passage goes through the IM flange into the head, where the copper crush gasket part is. i thought it was for EGR and figured it wouldnt hurt to reuse the IM gasket…well now i know its a coolant passage and now the heads on and all and a PITA to remove the IM and change the gasket…
update: got the IM gasket replaced and it starts and idles fine but i had it happen again with getting coolant seeping in while its off and makes starting rough. still not overheating…
anyone EVER had where the block deck was warped and or the headgasket was bad and DID NOT overheat? i’m out of ideas
