check the bumpers on the pedals… there are sensors(switches) under the dash that are actuators for the cruise control module. if the bumper isn’t there the module thinks the clutch is pushed in and so the cruise will not set. same thing with the tail lights. if the bumper on the brake pedal is missing the actuator will not turn off the tail lights when the brake pedal is released. I fixed mine with very short 1/4-20 bolts and a nut. bolt head facing the sensor. took me a while and some research on this site to figure the cruise thing out… don’t know why I didn’t think of this when I was able to figure the brake thing out myself. I guess the rubber cone and disk on the floorboard were tell tale when the brake thing came up. glad to have cruise back! thanx G2IC.com and thanx to serpunk182!!! you da man!
