ctr intake cam and b18c1 exhaust cam in b17a1
what u guys think about a ctr intake cam and b18c1 exhaust cam in my b17? is this a good setup with a nice tune since i am on budget? is their anyone that has had this setup on here or has a dyno sheet? i got i/tb/im/h/e and a chipped p61.
No need for the c1 exhaust cam it’s the same. save up for CTR/ITR cam set and springs. if your engines healthy and you have a good tuner, you should pick up a few.
Yes the CTR cam would yield more power… But you wouldnt/shouldnt rev past the stock redline of your B17 because of the stock B17 cam-springs. When you upgrade to more aggressive cams, you need to upgrade your springs as well, or else you’ll run into coil-bind and that will basically kill your motor.
As icemanGSR said, save up for a full set of cams & springs.
i shift at 8300 right now and am not planning on going any higher after the cams without valve springs. so the b18c1 exhaust cam is the same as the b17 or ctr? the thing is if i get stage 1 or 2cams then imma want springs and retainers and if i get those then imma want port and polish then fuel pressure regulator, injectors, fuel pump, msd, clutch, lsd, ect. u guys no the viscious cycle lol. i am going to do all this eventually when i have the money for a full head pakage but for the next year i should be fine right? i
save up for all the parts for the head and do it at once. it’ll be cheaper. don’t get the MSD it’s worthless. The stock ignition system has been proven to hold up on cars making 500+hp.
yeah keep your stock ignition with the exception of magnacor or ngk wires and plugs.
ngk plugs are std. ther is no advantage to aftermarket wires. the stock wires are fine, if you can’t find em, the ngk blues are a good alternative, but they are basically the same.
The exhaust cam from my pair of CTR cams was damaged so I paired the CTR intake cam w/ the stock P61 exhaust cam. Of course it’d be better to have the CTR ex cam as well, but I still made good power w/o it.
http://forums.g2ic.com/showthread.php?137294-B17-all-motor-builds-please-post-your-builds/page5
What he said. You may also want to start searching the internet about the flow capabilities of an in-spec Honda fuel system as it corresponds to your eventual power goals.
Another thing: I don’t know when this became popular, but why do you want titanium retainers? Titanium is not universally better than steel. I know that in general companies have been making Ti retainers for several years now, but that doesn’t mean that they are all making good ones.
I don’t know about you, but I have never heard (even before they started making Ti retainers) of someone saying “shit, my stock retainers gave out on my high performance engine. Fuck!”
Now if your valve spring seat pressures are insanely high, I could see an argument being made in some theoretical world for a less malleable material than the stock retainers but I just don’t see that as being an actual, practicable need.
Think about all the weight being thrown around by that valve spring and then think about the weight difference between a steel retainer and a titanium one and you will realize how silly it is to spend $150 extra just to “save the weight”.
do u have stock valve springs? and what are u shifting at?
