Alright, if I can’t figure this out wife is making me sell the car.
1992 GSR
Car is spitting the passenger side axle. The axle wobbles at the inner joint directly where it mates with the transmission. Has done this with 4 axles now, they even wobble when they are completely broken (even when not spinning).
I have spent the last 3 days replacing the front portion of the front subframe, both front lower control arms and the stabilizer bar and a couple of unrelated items because they all looked like they could have been damaged.
While I still had the car on the stand I started it up, put it in gear and let the engine rotate the axles at idle. The passenger side axle is still wobbling and therefore I’m pretty sure it’s gonna pop out again. I’m assuming that because it is wobbling at the transmission that I need a transmission rebuild.
If I can’t be nearly 100% positive that the next repair will fix the problem, I have to sell my GSR and drive a crappy EG with 205k miles for a year or so. :bawl:
