Dashpot vacuum line question
If this line isn’t hooked will this effect your idle? Since my charge pipes dont have any ports for hosses im trying to figure out what should be done. Also can anyone send or post there vacuum setups?
kevinwash26@hotmail.com thanks for any help
if your talking about what i think you are then yes. it helps keep the throttle body butterfly open when engine is cold. i believe w/o it you would have to keep giving it gas for it to stay running. if we’re talking about different parts then sorry…
hth
naw thats what im talking about…i just wanted to know if i needed to somehow have it hooked into the charge pipe or if it could be T eed into something else.
I don’t have any of the lines that run into the stock intake pipe hooked up, runs fine.
:shrug:
you don’t need it. i removed mine alltogether and no problems :up:
hth
then i guess i have some other issues because my idle is really really off…can anyone post a pic of their setup?
Remove it
i guess i will try that then…
mine is removed too. You dont need it.
Your bad idle is probably a combination of vacuum leaks. Turbo projects almost always seem to spring vacuum leaks. Also, if you installed new injectors, those seals could be a big culprit. My car is idling all crazy right now because of bad seals on the new injectors. You should pressure test the system and see what you find for leaks.
