The title more or less explains, does a DC hydro-trans clutch fit a 92-93 cable-trans? I know that 90-91, and 92-93 have a different spline count. Or at least I think so? Thanks.
yes and no
i know if its an ls or crv hydro clutch it will work in the 92-93 ys1 ls,gsr.
im not to sure if the hydro gsr,b16 clutches are different in spline count or not. i only use ls transmissons. i found it to be around .1 faster at the track(1 less shift)
im pretty sure all 92-00 bseries trannys have the same imput shaft(spline count)
This is correct.
Awesome. Thank you. Found a Comp Stage 3 with 500 miles on it locally for $150. Perfect for my up-coming budget turbo set-up.
